SL55/63/65/R230 AMG: Front clicking Brakes SL65
SL65
Ok guys ive looked all over and cant find much on this..The car makes a clicking noise when i step on the brakes similar to what a cv joint sounds like when its bad. , I was reading someplace about rotor springs?? But the car only has 16k hwy miles on it and plenty of meat on the pads..Any ideas?
Its only the left front.
2006 sl55 030 option - sold
A clicking noise in the front brakes is normally do to the pad or pads shifting. You would need to take it apart and check where pads ride.
Hope this helps
Hope this helps
Are you sure? They might look the same but 1 or 2 mm longer would be all you need to hit...I had this problem on my 996 turbo way back when. Had to buy new bolts. It would be odd that it is only 1 wheel..but odder things have happened.
SL65
Thanks for the help.
