SL55/63/65/R230 AMG: Removing SL65 Transmission , is it a DIY?
Old Apr 29, 2014 | 05:59 AM
SL65MONSTA's Avatar
SL65
Hi there just wanted to know if this is any different to other cars, or if I should leave this strictly to the professionals, also are there any other posts of people doing so ?
Old Apr 29, 2014 | 03:53 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Just like most cars but you do have more lines around the bell housing that control the ABC lines. No need to open any of them but just disconnect the lines form bell housing. IMO, you need a lift and trans stand but other than that, pretty easy.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
