SL55/63/65/R230 AMG: IC Heat Exchanger Fitted
Old May 23, 2014 | 03:31 PM
JohnH's Avatar
2004 SL55 AMG
Think I have just about finished the tuning mods to my SL55. Have fitted 19" AMG Type IV wheels, Quaife LSD, Removed Secondary cats and resonators, Renntech Lowering Module, Eurocharged Remap and SC Pulley and latest Bosch IC water pump. Had the Eurocharged (C&R) IC Heat Exchanger Fitted today and here are a couple of pics.
Before HE Fitted
After HE Fitted
Old May 23, 2014 | 04:06 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
looks good!
Old May 24, 2014 | 02:52 PM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
What about airflow over the oil and engine radiator? It seems like the IC radiator is blocking a lot of the air that would normally hit the engine radiator.
Doesn't car run hotter in warm weather 80F+ ?
Old May 24, 2014 | 03:47 PM
JohnH's Avatar
2004 SL55 AMG
Its the standard way of fitting and doubt thats a problem in the UK!!
Old May 28, 2014 | 05:49 PM
Tommyboy928's Avatar
89 SL500 Silver ,97 SL500 Carlsson 04 Mercedes SL55 AMG , 07 Mercedes SL55 AMG convertedBlack series
when you fitted,you hooked intercooler in loop with the old one , outfrom top of the standard intercooler ,and looped down to lowest inlet on the new one ,to have water flow up in that radiator, and come out on top and return via pump ?
Old May 28, 2014 | 06:07 PM
JohnH's Avatar
2004 SL55 AMG
I know they left the original Heat exchanger in but not sure exactly how the water flows.
Old Jun 5, 2014 | 04:06 PM
Jbobiccus's Avatar
Still looking
Correct me if I'm wrong, but isn't that bottom one you're talking about the oil cooler?
Old Jun 5, 2014 | 04:21 PM
JohnH's Avatar
2004 SL55 AMG
Yes the original Heat Exchanger is behind the radiator and still there.
