SL55/63/65/R230 AMG: 2004 SL 600 upper water hose to Radiator
Old Jul 9, 2014 | 09:49 AM
stykshooter's Avatar
SL 600
My water hose ( top of motor to rad. drivers side) has a leak just wondering if there's any secrets to replacing looks simple but nothing easy on these beast. Does the radiator need to come out ?? Any advise ...Frank
Old Jul 9, 2014 | 09:58 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
to replace the upper hose the radiator doesnot need to come out
Old Jul 9, 2014 | 10:12 AM
SL 600
Not much room where the hose connects to radiator, I've removed the hose this morning any tricks to attaching new one ??
Old Jul 9, 2014 | 11:16 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Try and attach the radiator side first, if room is tight on that end. Make sure the the clip is locked real well on the new hose and in the right slot.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 9, 2014 | 06:30 PM
SL 600
Got it on but didn't think it would take that much muscle to attach. I notice that one end of the hose is plastic & I'm wondering is the sides of these radiators plastic & if so can they leak ??
