SL55/63/65/R230 AMG: Plz Help me R230 Trunk lid drive cylinder
Old Oct 13, 2014 | 09:49 AM
Syun's Avatar
R230
someone can tell me some problem.
My R230 Trunk lid drive cylinder spill oli, i take out it (see picture)
I don't know the Trunk lid drive cylinder piston Rod top have thread , i know SLK R170 cylinder piston Rod have thread , so hope someone tell me ^^
i want to separate piston Rod and bracket(see picture) , How to separate it .
Very Very Urgent T_T plz~~~help~
Old Oct 14, 2014 | 06:13 AM
coldwell's Avatar
2006 sl55 030 option - sold
I do not think you can repair it. You just buy a new one and replace it.
Old Oct 15, 2014 | 03:31 PM
kittyandgary's Avatar
2003 SL55 AMG
Here are the part numbers for all the struts. The last one is what you need (do a google search on how to replace it, as the procedure is a bit tricky):
Hood (2 needed)
Mercedes-Benz: A 230 880 00 29
Stabilus/Lift-O-Mat: SG403057
Trunk (2 needed)
Mercedes-Benz: A 230 750 00 36
Stabilus/Lift-O-Mat: SG403056
Tubular Frame (1 needed)
This is on the right side of the car, by the battery, opposite the hydraulic cylinder that lifts the trunk lid backwards when you retract the roof. If you care at all for the life of your Vario roof hydraulics, definitely replace this one, right around when you replace the normal trunk struts.
Mercedes-Benz: A 230 750 01 36
Stabilus/Lift-O-Mat: SG303007
The Stabilus/Lift-O-Mat struts are available via the internet, and cheaper than the MB dealer.
