That's true. It seems the kit you posted is just someone in Germany piecing parts together to make a "kit". You'll have to contact Bilstein in US to get the shocks, Eibach to get the springs, Mercedes USA to get the pump and sway bars (tough chances it wont ship from Germany). Sounds like a lot of hassle.
FlyinFINN,
I agree, not worth the risk.
Would like to see a good write-up and pix from
the Florida company.
+1
I've been hoping to see "Rebuild Mastertech" do this for a while.
Does seem to be a good and complete kit (including sway bars), but before I make a move, I need to see and hear installation details, along with opinions from owners.
is me or shouldnt the s class w220 or e55 power steeering pump work on the sl55. it think the few who did the coilovers on the cl and s class used w220 non abc pumps. when i lookup the part number for sl350 230.467 i get part number
A0024668601 and A0024668701 when is also compatible with w220 s class non abc cars. they can be had on ebay for $150 or less. the pump shown on the rebuildmaster kit looks like a non abc s class pump w220. part number A 005 466 40 01 on the epc show it as sl350 r230 454 456 and 458. what do u guys think.
I have been in talks with a suspension company here in Florida, looking to get SL55 fully adjustable coilover kits made - with sway bars and potentially custom front control arms for additional steering angle. If interested, feel free to message me and I'll take down your name. Most likely there will be a group buy initiated within the next month - bringing the cost down for all first customers.
Start a new thread with info and pix for the 1st group buy.
A quality package with all parts may get a big response.
I don't believe the SL55 kit will fit the SL600. Another member here was having a kit done from these guys http://www.ebay.com/itm/Coilover-Conversion-KIT-Mercedes-R230-SL55-AMG-2002-2008-OEM-Incl-Core-Deposit-/201195406437?hash=item2ed82e4465&vxp=mtr
I too am interested in getting rid of the ABC on my 600.
Well, the car is finally done, what I can say is the following after driving the car for almost 70 KM. The wheelspin is less than it was, the suspension makes it feel like a race car. It feels stiff, though until now I could feel that the car is more stable.
The car lost at least 40-50 KGs, the ABC suspension is a heavy one.
The kit I bought had H&R Lowering springs, which made the car stable and low.
Until this moment I can say that I'm glad I did this conversion.
Hi there ? Wow so what about the Part Numbers for the Shocks & Springs ?
Also What did you do about sway bars ?
The Warning ABC Error Codes ?
I have already completed my coil convention. But, I still have the ABC warning in my dashboard. Any way I can remove it?
Originally Posted by JadAwada
Hello mates,
Well I'm writing that my car is being converted from the ABC suspension to Coilovers. The suspension of a used NON-ABC SL350 R230.
Monday the car will be done, I can't say that I'm not afraid of the changes that might occur to the driving quality. I'm concerned about the stability of the car, and the danger that those struts will not handle the power of the 55 AMG.
I took the risk to be doing this conversion, knowing that I might regret it. But ABC became tiring with too many failures occurring.
The conversion costed me 800$ + all the ABC parts. Including the installation. I noticed that the new struts have H&R Springs Lowering kit.
On monday, I will get back to you either telling you guys to do this conversion, or never consider it.
Here are the part numbers you might need for the conversion:
QUOTE=Geo3;6317061]On the Black Series SL65 (coilovers and no ABC), when you do a "quick test" via the Star Diagnosis, there are current fault codes in control units that show as "this fault code can be ignored in Black Series models" after the DTC.
Therefore, it appears possible, with any similar coil-over conversion, to simply have the Star Diagnosis, clear the codes and warnings.
In an an email reply I received from "Rebuild Master Tech", in Florida, following their installation, you only need a Mercedes scanner to remove the ABC option out of the car's computer. No module is necessary.[/QUOTE]
Hello,
I have completed the coil conversion. However, I can't remove the ABC warning. I tried to remove it with my star scanner but, I only have option SL65. Can't see (black edition)?
Any help will be great. I live in Austin,TX
HI…I own 2004 stock SL500 that has about 125000 mi haven’t owned the car no more than 10 mo. I’ve owned many sports cars in my life this is a fun car to own when it is not in the shop. The ABC system is probably great when new and under warranty but at 11+ yrs old its warning out. my driving habits is for pleasure only. It’s not a SL55 or a SL600 just a stk 500 w/ no sway bars. About 2 mo. ago I blow a suspension line after just replacing the tandem pump thinking not a big deal only to find out the engine had to be raised that was the last straw. I started reading here about converting to a coil over system I know all you Mercedes purist think you need to kept throwing $$ into the ABC system but not me. I had a coil over done also took out tandem pump and had a P/S pump only installed it has made driving the car fun again the ride is as good as it has every been I don‘t race the car just a fun car to own and drive . Funny but maybe all of you w/ low mileage cars wouldn’t mind driving them again if you were to get the coil over lets face it the car isn‘t going up in value. One more thing keep doing the rodeo on your cars the pump mfg and Mercedes parts and service dept just love it , this is just my 2 cent…
Removing ABC from the system on a SL500 is done here in STAR DEV
When going in to ME28 F3 stand -> Explizite Kodierung on the car (not in SIM)
All models w209, w220 and so on are listed and all drop Down menus, also R230 is with dashes - - - -
Under R230 the following options are available (EU3EU4 ULEV and JAPAN)
NOTE: here only the EU3EU4 options are shown
NOTE NOTE.. If you don't know what youre doing, leave it to someone that does !
Use this coding for NO ABC and WITH DISTRONIC
R230_M113_E50_EU3EU4_NAG_ART_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
Use this coding for NO ABC and NO DISTRONIC
R230_M113_E50_EU3EU4_NAG_VGB_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
Use this coding for WITH ABC and WITH DISTRONIC
R230_M113_E50_EU3EU4_NAG_ART_ABC_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
Use this coding for WITH ABC and NO DISTRONIC
R230_M113_E50_EU3EU4_NAG_VGB_ABC_250_km/h_KickPWG_PKK_MRM_1131531279_1131532779_1131533079
Good luck...
Well done and many thanks for posting this valuable information......Geo.
