SL55/63/65/R230 AMG: SL5 AMG Steering Wheel Shift Buttons
I. Just purchased an 03 SL55 AMG and I can't get the steering wheel shift buttons to work. By reading post on the forum I know on an 03, they will only work in the M mode. I also read a Lot of pros and cons on converting to paddle and it seems to be a 50/50 that you can or can't. I might tackle that at a later date, after I get mine working with the button. I took the steering wheel air bags (after disconnecting the battery of course) out and removed the buttons. I've checked them and they seem to work correctly. Using a meter I determined one circuit is open and one closed, as I found in my research is correct. Now I need to hear from the experts where I go from here. I have no idea what to check or how to troubleshoot further. I might add the manual shifting works ok using the shift lever. Thank you.
Doug
Has anybody done any work to the wheel or removed it or replaced it to a different style
I had the paddles installed and I can tell you it beats the hell out of the buttons. It was a simple process where I was sent a new wheel with the paddles pre installed and then took it to my indy. He replaced the steering wheel in 20 minutes and it's perfect. It was plug and play.
Chris who is the manufacturer is on the forum and hopefully can chime in and help with the possible cause of your problem.
have you verified that the touch-shift works .... and to be clear, you are in Manual mode (and moving)?
testing the buttons dynamically can be tricky ... if you still have them out of the car, hook the wire from the up button to +12vdc (through a 1k ohm resistor) and the wire from the down button to ground and then check between ground and the up switch (to 1k resistor junction)
1) neither switch depressed 5 to 6 volts dc
2) up (right) button depressed 12 volts dc
3) down (left) button depressed 1-2 volts dc
indicates normal
to probe this further (or in the car)
the 2 pin connector under your air bag has one lead going to ground and the other to pin 4 of the connector on your floor shifter. If you were to probe the latter (and I hesitate to recommend it as you are messing around in live air-bag territory) you should find (reading across the 2 pins
with the meter set to dc volts) these 3 voltages (based on switch operation).
2) up (right) button depressed 12 to 14 volts dc
if you want to send me a PM, I can perhaps guide you through some testing of this.
and, when you get to the point of wanting paddles, I can certainly help you with that.
Cheers,
Chris
I'M NOT SURE IF I AM DOING THIS CORRECTLY SO PLEASE FORGIVE AND I HOPE THESE ATTACHMENTS ARE VISIBLE.THEY SHOW MY C55 STEERING WHEEL WHICH I CHANGED FROM BUTTONS TO PADDLES WITH A SIMPLE PROCESS AND WILL WORK ON ALL MODELS THAT HAVE BUTTONS FITTED.
I HAVE TRIALED THEM ON MY CAR IN THE UK AND THEY WORK PERFECT AND ARE GOING TO BE TRIALED IN THE US.ALL ENQUIRIES ARE WELCOME
