SL55/63/65/R230 AMG: SL 65 Engine cover removal question
Old Aug 19, 2015 | 04:07 PM
abiazis's Avatar
SL 65 AMG, Porsche 911 (993), 2014 Cayenne GTS, 2013 Toyota Highlander Limited
Question SL 65 Engine cover removal question
Are there any tricks to taking the cover off or do you just pull up to release clips, etc? Any tips appreciated......thanks in advance.....
Old Aug 19, 2015 | 04:57 PM
RaceHorse's Avatar
CL65
Shame on you, you have this car for a while haven't you? LOL, Anyway, start in the front with the metal portion, pulling it straight up slowing, then the back has 2 larger pins attached that will slide out (closer to the firewall). After that, lift the carbon fiber portion the same way, there is a bit of tension, but it will release, making a little noise. Same thing to re-install. As you push on the carbon fiber piece it will make a snap sound as it secures itself. Its very straight forward, simply center over the oil filter and it will go on.
Old Aug 19, 2015 | 05:07 PM
abiazis's Avatar
Thanks Racehorse.......yes I have had it for some time, love it.....but never had to take engine cover off myself due to warranty work on other stuff under that thing being done by my indy and he once said something about it being a *****......thanks for the details because the V- 12 always has some type of special handling))
Old Aug 19, 2015 | 07:20 PM
RaceHorse's Avatar
CL65
Not a problem, go get a ECU/TCU and fall in love with it all over again.
Old Aug 21, 2015 | 01:48 PM
abiazis's Avatar
Not out of love yet......Not a bad idea though, but car is so smoking fast as it is....)
