SL55/63/65/R230 AMG: Canadian Always on light - switch off?
I have a Canadian spec'ed 2003 SL55 and the car is now in the states.
I noticed that the lights are always on no matter what light switch setting it is at. I think it is the law in Canada to have always on lights?
So, I was wondering if any of you know how to turn that setting off? can it be done with a regular OBDII? or what tools are required to do that?
The reason I'm asking is because my HIDs just burned out and if its always on, I will be replacing it much sooner than it is necessary.
Thanks,
J
Shaun
I looked into lighting, but it is not there. Not sure, where it is.
J
Here is the path I found in DAS SIM starting from the very beginning. Cars/SL/SL230/(f4) 03 to 06/steering left/sl55/ROW/control units/body/central gateway/control unit adaptations/code reading change if necessary/driving lights/exterior lights national version/
Change the drop down from Canada to USA.
I hope this helps and is the right place. Otherwise, apologies for sending you on a wild goose chase.
