SL55/63/65/R230 AMG: 2007 SL55 AMG
Old Mar 22, 2016 | 06:55 PM
amg_nik's Avatar
2006 C55 AMG
2007 SL55 AMG
Hello everyone, I recently purchased a 2007 SL55 from the original owner. It has only 60k miles, but I have some concerns. There is a weird issue when i am driving at a steady rate. Right around 2000 rpm, if i keep the throttle steady, the rpm needle jumps up and down about 50 or so rpm. I can feel the car not steady as well. I have a check engine light for p0422. In some places it says bad o2 sensor while others say the cats need replacing. I took the car apart last night on the top end and found a small oil leak from my valve cover gasket as well as a hole in my left intake tube (the black flex plastic tube connecting the airbox to the grill). Could the cel and intake tube be the cause of my problem? Not sure what it could be. My supercharger belt seems to be in good condition so i don't think it is a slipping issue. Thanks.
Oh and I am new to this forum! seems to be lots of enthusiasts
Old Mar 22, 2016 | 07:16 PM
yoyo7112's Avatar
2012 CL550
first check the spark plugs and o2 sensor
Good luck !!
Old Mar 22, 2016 | 09:32 PM
Nor Cal SL55's Avatar
2012 E63 AMG
I don't think the valve cover leak or the plastic intake tube are your issue. I really don't have anything else constructive to add to your engine miss question, but WELCOME to the FORUM!!!
Old Mar 22, 2016 | 09:41 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
go with your diagnostics
Old Mar 22, 2016 | 09:54 PM
amg_nik's Avatar
2006 C55 AMG
I do not think the Valve cover gasket is my problem, just mentioned that i found the intake hole while replacing my gaskets. As far as diagnostics, I only have the one code for p0422 but there are some that say it is an o2 sensor while others say the cats need replacing. Maybe a spark plug issue? Any recommendations for spark plugs and wires? I hear evosport are good for wires but can't seem to find them. Thanks all!
Old Mar 22, 2016 | 11:38 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
buy OEM wires and the stock NGK spark plugs, but neither are likely your problem and the wires should be good for the life of the vehicle and the plugs good for 100k.
It is a code that the reading from your oxygen sensor is out of whack. This could mean the cat is bad or the oxygen sensor is bad. It is probably cheaper to start with the 02 sensor to see if that works. The cheapest place for MB parts I've found is huskerparts.com (they are an MB dealer that sells online).
If you are going to DIY at all on these cars you need to buy a STAR diagnostic setup. It is an investment that will pay for itself very quickly.
