SL55/63/65/R230 AMG: larger idler pulley on belt wrap kit
Old Sep 2, 2016 | 04:06 AM
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
Shardul, do you have a larger pulley for the belt wrap kit I purchased from you? There seems to be clearance for one at least 50mm larger in diameter, which would further wrap the belt around the drive pulley, especially the 77mm pulley I have ordered. The rpm of the pulley would reduce also, extending bearing life. Sorry, I needed the tune is why I didn't buy from you. Cheers
Old Sep 2, 2016 | 02:15 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Sorry we dont have a larger pulley for the BWK
Old Sep 2, 2016 | 04:50 PM
trabots's Avatar
Thanks Shardul.
Old Dec 12, 2022 | 07:00 AM
AMGenema's Avatar
2003 SL55 AMG
There are many that make pulleys. VRP, UPD, and a place in Arizona. You should be able to find what you need. Holiday pricing should be starting soon, Good luck.
Old Dec 19, 2022 | 12:10 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We make tons of idler sizes and everything is in stock.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
