SL55/63/65/R230 AMG: Exhaust drone
I have a very bad exhaust drone at low rpm and its so annoying .. Exhaust mod are EC headers all cats delete except mufflers. Cats replaced with with 2.5-3" striaght pipes ..
If i added a 3" xpipe would that eliminate the drone ?
Adding back resonaters or secondary cats is not an option.
Adding back resonators or secondary cats is not an option.
Also, the secondary cats replaced with a 2.5" pipe, resonators replaced with a 3" pipe i guess, while primary cats replaced with 3" ... Is that difference in pipe diameter makes a dramatic effect ? Should they all be changed to a 2.75" like OEM ?
Already ordered an x-pipe, should the H-pipe be deleted and replaced with X-pipe ? Or keep it and add X-pipe ?!
Would recommend installing a high flow catalytic converter or two because it's better for you and environment and will sound way better with much smaller loss in power.
That or try something less traditional and have them build a small length of pipe and cap the end of that - helmholtz resonator style... can be very effective at removing resonant frequencies.
