SL55/63/65/R230 AMG: DUDMD - SL65 AMG V12T - Single Turbo Conversion Build
#51
Correct, right side of the exhaust is now only for waste gate dump.
The sound is much cleaner than the normal m275, but also quieter than my old setup.
#53
Received 1,069 Likes
E55, GLS450, GL63, GLE350
#63
#66
2103 SL 63 AMG
How's the suspension going with the ABC delete?? I've been down to your shop with the silver SL 55 AMG. I'm just now replacing my second hose on my ABC system in the last 6 months and would really like to know how the coil over conversion went.
#67
The V8 pump conversion with custom brackets/hose work perfectly fine on the v12.
#70
You need a filter. You're basically ingesting everything into the engine not to mention the finer particles will "sand blast" the turbine wheel.
#71
There's only about a 1" gap between compressor inlet and the shield.
#73
2009 SL63 Rear Mount Turbo
#75
