SL55/63/65/R230 AMG: Speedriven IC Pump
Old Jan 31, 2017 | 05:02 PM
PDC's Avatar
PDC
2006 SL65 ///AMG - GONE BUT NOT FORGOTTEN: 2005 E55; 2002 ML55; 2001 CLK55; 1992 BMW 850i; 1991 M5
Speedriven IC Pump
Has anyone here installed a Speedriven IC pump yet? I understand you need to upgrade the wiring and the fuse because the Speedriven / Pierburg unit draws more current than the factory Bosch unit. Does Speedriven provide the new wiring for the install?
Any benefit to upgrading the pump if you are not also stepping up to bigger intercoolers or heat exchanger?
I've got the '010' Bosch unit that was all the talk a few years ago with stock intercoolers and HE on an 06 SL65 with a KLEEMANN tune.
Thank You!
Old Jan 31, 2017 | 05:38 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I can get you that pump. It has 4 pins on it and you will only use 2. Since the other 2 control the speed via signals from the ECU (different application car)
It is the similar pump renntech also uses.
