SL55/63/65/R230 AMG: Rebuild post 2007 valve block
Thanks much
jc
When I did mine, I was astonished at how hard it was to get the solenoids off.
All the instructions I had read said something on the order of "twist 45 or 90 degrees and the solenoid / valve body comes off". Yeah, right! It took a padded bench vice and careful use of a small pipe wrench (covered with a piece of cloth) to break them loose and get them to turn, and they would happily spin in place 360 degrees without any indication that they were ready to separate from the valve block. I had to turn and pull at the same time to get them to disconnect from the valve block. Would have been easier if I had looked at the many photos available that show how the solenoids lock into the valve block, but I tend to learn the hard way.
Hope this helps - If it is something else, please revert back with your solution and help the whole group learn.
