SL55/63/65/R230 AMG: Replacing factory COMAND - Need assistance
Old Mar 9, 2017 | 02:53 PM
braddman's Avatar
2005 SL65 AMG
I'm replacing the COMAND headunit with aftermarket. Do I need the male or female fiber loop for behind the radio when I remove it? Does the COMAND radio have a male or female connector on the back?
Old Mar 9, 2017 | 04:37 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
My understanding is that once you disconnect your head unit from the loop .... it becomes irrelevant as your fiber optic no longer does anything.
Chris
Old Mar 9, 2017 | 07:52 PM
braddman's Avatar
2005 SL65 AMG
Chris
I need to keep the loop I have another device still operational on it
Old Mar 9, 2017 | 08:11 PM
while I remain skeptical that anything on the ring would function once the command unit is removed....
if you look at this EBAY add for a 2005 command unit, you should be able to get your answer from the fourth picture,
http://www.ebay.com/itm/2005-MERCEDE...1Yfqp1&vxp=mtr
hope that helps,
Chris
