SL55/63/65/R230 AMG: Sl55 amg 2004 64,000 miles ABC light still on
Old Apr 19, 2017 | 07:13 PM
graham1965's Avatar
Mercedes SL55 AMG
I changed the rear left travel sensor to fix the fault as that was the only fault found on my laptop The suspension still will not go up or down ???
Still shows on the dashboard ABC with one malfunction if I clear and reset the cars computer will this now make the suspension work normal again
Old Apr 19, 2017 | 08:41 PM
mAMG's Avatar
SL55 2003
I just had the same problem, it was the rear left travel sensor. I've been told that if the sensor is changed and the problem is not fixed then its going to be thr ABC module has a loose connection or needs to be changed.
