SL55/63/65/R230 AMG: D1S replacement on R230 SL63 AMG 09-12
Old Mar 31, 2018 | 01:42 AM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
Question D1S replacement on R230 SL63 AMG 09-12
Hello AMG fam,
I have searched and i realized 09-12 SL63 have a small population of owners here!
Anyhow, has anyone ever replaced low beam Xenons on SL63? my SL55 has D2S and was pretty accessible via under the hood, but i am unsure about the D1S on SL63. Do you access from the wheel well, by removing splash shield?
Any inputs would be great fam!
thank you
Old Mar 31, 2018 | 10:09 AM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
all the bulbs are replaced the same, take the door off and take the bulb out. You cant get anything from the wheel well. All you do is open the hood and take the doors off. You cant see anything but you feel the clips off and pull it out/ put it back. The drive side is hardest but Ive done them many times.
If youre into excessive labor you can disassemble whatever you want
Old Mar 31, 2018 | 08:01 PM
SGTzAMG's Avatar
Veteran: Army
Thank you! i appreciate your feedback. Are the projectors/bi-xenon on the SL63 dynamic or auto leveling? since the SL55s aren't.
but another Question, since the SL63s are 145K+ cars, is is uncommon for these cars to not come with keyless go?
Old Mar 31, 2018 | 09:44 PM
okbarnett's Avatar
the 09 up had keyless go included with P1 pkg. I saw one car w/out
Old Apr 1, 2018 | 04:48 PM
SGTzAMG's Avatar
Veteran: Army
thank you!
are the headlamp projectors dynamic/auto-leveling?
Old Apr 1, 2018 | 04:51 PM
SGTzAMG's Avatar
Veteran: Army
What does P1 package consist of?
I am currently awaiting for an 09 SL63 black on black to be transferred and shipped to me. Coming from GA, so i can fully inspect the car in person. The car has black seats, seems to be 040, pano roof, heated/ventilated seats, air scarf, black piano wood trim, i saw a photo of the shift knob, but because of the angle, i am unsure if the top of the shift knob is the keyless go or not. Also, the car has the fiat bottom steering wheels with the cut out at the bottom of the 6 o'clock spoke, which i didn't see on other SL63s could it be a 2009 thing?
I asked the sales consultant RE: more info about the car, but the person is not knowledgeable one bit about these cars
Old Apr 1, 2018 | 11:00 PM
okbarnett's Avatar
I think the lites are leveling. And dont remember what p1 has. flat bottom wheel is performance pkg with LSD, 2 spoke wheels, cant remember what else
You can get the options by vin; You really should have all that before you buy anythng. Also 09 had a couple problems with 6.3. I think head bolts and lifters. Some were recalled, some had bad problems. You really need complete inspection at MB and look at the master sheet, complete warrantee history.
http://carinfo.kiev.ua/cars/vin/mercedes
Old Apr 2, 2018 | 01:47 AM
SGTzAMG's Avatar
Veteran: Army
I appreciate it so much!! yes i am in the process with requisition for a full carfax, but i do want to ask my service guy to see if he can look into service records of this car via VIN.
I appreciate the link btw! although i am trying to understand since it seems to be in Russian?
Old Apr 2, 2018 | 11:17 AM
okbarnett's Avatar
just put in the vin and if you have to you can set it to english if it isnt automatic
Old Apr 8, 2018 | 11:42 AM
Nor Cal SL55's Avatar
2012 E63 AMG
A 2007 SL P1 package contains: Keyless Go, Active Ventilated Seats, Multicontour Seats, and Bi-Xenon Headlamps with Corner-Illuminating Fog lamps. I know the 2009 was a facelift model from the 2007, but this may give you and idea of what may be on a 2009 model. HTH
I did find this on-line:
2009 SL - Premium 1 package (P01)
  1. Driver and front passenger seat front seat ventilated, climate-controlled and active/massage
  2. AIRSCARF
  3. Power liftgate
  4. Smart card/smart key with keyless entry includes keyless starter with memory seat on memory steering wheel
  5. Card key power locks
And another
Premium 1 Package - This includes Active Ventilated Seats, Keyless-Go, Electronic Trunk Closer and Airscarf - Active Ventilated Seats
And another
P1 Package (Bi-Xenon Headlights, Heated & Cooled Seats w/pulse & multi-contour adjustment, Airscarf w/Ventilated Headrests, Electronic Trunk Closer, Keyless Go)
Old Apr 19, 2018 | 01:20 PM
SGTzAMG's Avatar
Veteran: Army
  2. AIRSCARF
  3. Power liftgate
And another
And another
Thank you!
Old May 5, 2018 | 02:11 PM
SGTzAMG's Avatar
Veteran: Army
Osram CBB vs factory Osram
Replacing the D1S was way easy than what I anticipated it to be.
see attached photos of the new D1S bulbs, Osram CBB (cool blue boost) 7000K, theyre not blue at all, theyre crisp white like the new models with LED headlights VS factory Osram 4300K. It's a night and day difference
