SL55/63/65/R230 AMG: Roof not working.
First thing to do and probably the cheapest thing to do is check the volts of rear battery. If its only reading like 6 volts chances are high the battery just needs to be replaced. If its like 11 volts you can put a trickle charger on the trunk battery and leave it on for a few days. A good trickle charger can actually bring a battery back to life. Then unhook it and check the volts of the battery and then start the car and see if your roof works, great if it works you found the problem. Then monitor the battery after that. If it sits a day or two and the roof isn't working again then just replace the battery.
If the battery is original or more than 6 years old just replace it to start with and even if it doesn't solve your problem at least you took care of maintenance issue.
In this case, most function/system will be limited, for instance: AC blower 50%, seat heater, roof top, radio etc........It depends on the battery condition and what stage of consumer shot off was activated.
Actually, the message will be popup in IC.
This was my reservoir this morning, your level should be near the top of the top triangle.
Pump is under the trunk in the spare tire area, lift up the foam noise insulator on the left side and you'll see it.
