SL55/63/65/R230 AMG: Brake squeal.
Old May 22, 2004 | 02:46 AM
pablo4.2's Avatar
06 SL600
Brake squeal.
Does everybody have some brake squeal? Mine increased so I bedded in the pads a little. The squeal was reduced to almost nothing and now back to some squeal (not a lot but noticeable on low speed normal and light pressure stops). I don't have any squeal when I brake hard or with authority. Thanks.
Old May 22, 2004 | 11:06 AM
dinko's Avatar
CLS55
That's a common problem with the 2003-present SL's. I can't say anything to help you with that, good luck!
Old May 22, 2004 | 11:00 PM
Hussain's Avatar
too many to list
I dont know if this helps...but I had the same problem on my 04 G500 and 03 S600 and I just went in and they replaced the "defective" brake pads under warranty.
Old May 23, 2004 | 08:56 PM
RJC's Avatar
RJC
Various
It's best to have your dealer replace the pads AND rotors.
Old May 24, 2004 | 12:07 AM
Twinturbo's Avatar
Although it would be great to get new rotors, I doubt they would stop the squeal. The cause is usually due to dirt in the brakes. Try give the whole area a good clean when the pads are changed, and make sure they put generous serving of high heat type grease behind the pads. This is put on to stop squealing, so this may be a cause of squealing.
Old May 24, 2004 | 12:44 AM
pablo4.2's Avatar
06 SL600
Thanks to all.
Old Jun 1, 2004 | 05:06 PM
pablo4.2's Avatar
06 SL600
Dealer installed new pads all around and now I have no squeal.
