SL55/63/65/R230 AMG: sl 55 amg 2003 abc problems
Old Apr 29, 2018 | 08:34 AM
Helge Hanssen's Avatar
SL 230 55 AMG
have a problem my sl55 givs me error message on the abs system i can rais or lower the car and put it in race mode, no fault but i stil get the message abc mailfuntion
enywan have an ide?
Old Apr 29, 2018 | 10:29 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I'm guessing it is in white? Race mode? Do you mean sport?
Old Apr 29, 2018 | 01:18 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
If this only appears when you traverse a bump, then very likely one or more accumulators are bad. Diagnosis would be confirmed by testing the accumulators with Star Diagnosis.
Check the level of hydraulic oil in the ABC pump reservoir and verify that it is correct. If it is and the accumulators are not suspect, then you really need to have diagnostic codes read from the ABC controller with iCarsoft, Star Diagnosis, or a similarly-capable diagnostic tool.
