SL55/63/65/R230 AMG: Abc problem !! SL 55 Amg 2003
Old Aug 9, 2018 | 12:22 AM
Iamneenoo's Avatar
SL55 Amg
Hello guys, i am new hear to share with you my problem and i decided to tell you about it because i didnt find any commun problem anywwhere, iv been driving my SL 55 amg 2003 model 2 years since i baught it with no abc problem, now from one month with no abc visting workahop while driving the car go up from the right side then it drops and sometimes it just drop then go up normaly and all the time the body role is feeling like a rodeo all hapenning while driving normaly on the highway, i changed abc fluid and filter 2 days ago and still have the same problem, i wish anyone can help me and share ur opinion of what could be causing this problem, thank you!
Old Aug 9, 2018 | 04:37 AM
dafi129's Avatar
SL 55 , Infinity FX37, Aprilia Caponord Rally
Hello , most probably your valve block seals gone . If playing front side , then it's your front valve block .
If playing rear side , then it's your rear valve block . They have four pistons each and seals could be gone
so no proper pressure inside the block .
Old Aug 9, 2018 | 07:20 AM
Iamneenoo's Avatar
SL55 Amg
Thanks a lot man! Will update u if it works in the next few days
Old Aug 9, 2018 | 05:57 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by Iamneenoo
...it drops and sometimes it just drop then go up normaly...
The problem is surely contamination of a valve block. A pair of 15-minute Rodeo Routines executed back-to-back has the potential to fix the problem. Otherwise valve block replacement or rebuild is indicated.
Old Aug 10, 2018 | 06:44 AM
Iamneenoo's Avatar
SL55 Amg
thank u so much)
Old Sep 8, 2018 | 01:15 PM
Iamneenoo's Avatar
SL55 Amg
Hey Guys, I did what you requested and my car is back to life ! Valve block was the problem Front right and left rear has been changed !
Old Sep 11, 2018 | 08:11 AM
dafi129's Avatar
Majority of ABC problems are from the Valve blocks . Mine anyway .. I invested in a set of seals
and changed all seals on front and rear . SO far so good ..
