SL55/63/65/R230 AMG: Simple heat exchange solution?
Old Sep 30, 2018 | 10:28 AM
skiendog's Avatar
'12 Cayenne Turbo, '12 GL450, '03 SL55, '89 560SL,
What's the simplest, most direct-fit, get-****-done-easy-cheap solution to either upgrading the heat exchange or adding another unit?
SL55 with EC 77mm pulley and EC tune.
Old Oct 2, 2018 | 11:10 AM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
there is none on the SL55. The easiest is Weistec as it is the only one that is plug and play that I am aware of, but it is $$$$. The cheapest is to buy an exchanger from ZZP performance and modify a few things to fit. There is a thread if you search of someone who did the ZZP one that outlines the exact modifications necessary to make it fit. I bought the ZZP, but haven't gotten around to putting it on yet.
