SL55/63/65/R230 AMG: Soft close
Old Dec 16, 2018 | 05:51 PM
Jay Page's Avatar
93 vette
Soft close
the trunk motors down to where it’s completely closed, then motors back up to where it first engages the latch. I don’t hear an air leak. It it was leaking would it do this or not work at all?
Old Dec 16, 2018 | 09:55 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
The issue I had:
The hydraulic motor would bring down the trunk lid, and everything would stop there. If you listen close enough, you would hear the valve and pump continue to cycle for a few seconds, and then eventually time out, without the latch "click". The trunk was physically loose where you could lift it up and down a few millimeters.
Upon taking part the trunk lid, I noticed that there were cracks in the plastic round the ball seals and the hose connections. I decided to try a little bit of epoxy as a quick fix before purchasing the entire replacement latch. It ended up working. The result was a quick latch and the valve and pump stopping rather abruptly and not continuing to cycle and time out like before.
