SL55/63/65/R230 AMG: Upgraded IC pump but no change
Well my biggest nightmare came true.
I changed my stock IC pump to the Bosch 010 and I still can only get one or two hard accelerations and then when I press on the gas pedal, I get an acceleration slower than a Yugo.
Power returns after I drive slowly at low
RPM's for 5 minutes or so.
I'm disgusted at this point. Don't know what to do next.
Any input will be appreciated.
The system should self bleed - but there are lots of posts on this site and U-tube on how to bleed the intercooler system.
Here is an informative thread on MBWorld. Look at post #25 and make sure you look at the left (R230) coolant system set up photo for your car.
https://mbworld.org/forums/sl55-amg-...problem-2.html
This is for bleeding an intercooler system on a W211 - E55, but describes the same techniques. Lots of information in the E55 section of the site that relates to your 2003 SL55.
https://mbworld.org/forums/w211-amg/...-pictures.html
Datalog your IATS..is the pump even working? Check your fuses.
Have you replaced the pedal yet?
You can get a cheap WiFi or Bluetooth dongle on eBay.
I was driving with a dead IC pump and never even knew, I think I hit it as high as 195 and it still pulled and pulled, never reached 210 where the shut off is.
