SL55/63/65/R230 AMG: Cooling upgrade help
I'm leaning towards the Weistec Dual Pass H/E, but considering the VRP Speed unit as well.
Has anyone installed either of these H/E?
Any recommendations would be appreciated. The pricing is basically identical unless I go with th XL version VRP unit which is $50 more but it's coolant capacity increases a bit more.
the coolant leaving the SC was 60 degrees cooler.
The stock heat exchanger is about the size of a clipboard between the radiator and a/c condenser, which is way too small.
With these two mod's I have no problem with it going limp.
Only ways I know of to alleviate this is to either install 1 or more larger intercoolers or utilize a killer chiller system that feeds off your AC system. I did the latter, live in South FL and generally cruise around at 8-9 degrees below ambient conditions ( have seen as much as 23 degrees below ambient on a fully warmed SL55 engine with mid - 70's ambient environment).
