SL55/63/65/R230 AMG: 03 SL 55 AMG ABC low onw side
2003 SL55 AMG
I recently had the pump replaced as well as the right rear height sensor. The car now sits low on left side...at normal ABC maybe 3/4...1" low both front and rear. Pump raises and lowers OK. Shop redid settIngs/whatever and did the "RODEO." Did not fix it. Car sat for about two weeks and the RIGHT side was the low side when I returned. Reset via ABC pump and now back to low left side. Shop says something got "dislodged" in the repair/flush process and I need to drive it a while to see if it corrects itself. I find it hard to believe both front and rear would have the same issue as a result of dirt in the system. I lean toward a "calibration" issue related to the Star diagnostics.... Any input/suggestions would be appreciated.
2003 SL55 AMG
I'd "assume" they did that when I took it back....I know they did the rodeo as I watched....but I will check with the shop to be sure. Thanks !
