SL55/63/65/R230 AMG: Leaking abc pump... how long have you driven?
Mechanic found a leak coming from the ac pump fittings. It appears to be a slow leak as of now. I plan on just checking abc levels each time I drive.
Curious how long have you guys let this leak go on for before getting it repaired? I'm just not financially ready to fix the abc pump yet.
Thanks!
It could be just a cheap o-ring or maybe the hose at the fitting.
I'd probably fix before it blows and causes more issues on top of leaving you stranded. Right now it could be a very easy and not that expensive of a fix.
