SL55/63/65/R230 AMG: abc problem
abc problem
i was saying my car had a problem when i park the car Front Left side slowly go down. and i have to run the car for a while to raise it again. manual rasing buttons light up but does not lift the car up
and so i recently replace the abc front valve block but now car comes up, manual rasing buttons light up but still does not lift the car up and after 30 mins of driving the car, i turned it off and on the engine, manual rasing buttons start working but Right front side of the car go all the way down now and as soon as i turn the car off, car fix itself to normal but if i put in the drive. front right side go all the way down. basically as soon as abc start working front right side go down. anyone know why?
05 sl55 amg
05 sl55 amg
Candidly, that post is too poorly written for me to get any sense at all of what is happening with your car. Perhaps you can take your time and compose a more easily comprehended explanation of the problem your are experiencing.
SL55 CL600 and 335D (rip flood) 325ci
Make sure you didn't reverse the plugs or hydraulic lines. I did this. Very frustrating. Right after I rebuilt the front block. Slammed on one side. I'd try to level the car and as soon as I moved even a little it "slammed" on one side. I had reversed the plugs. Possible the lines but I went back to scratch until I figured it out. I have since done the rear blocks on my CL and the from blocks on my SL55 and learned my lesson. Mark the plugs and lines after super cleaning the entire assembly and area.
