SL55/63/65/R230 AMG: AutoTalent | Renntech Brake+Exhaust+Intercooler For Mercedes-benz Sl 65 Amg BS
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Front Brake Air Ducts!
RennTech SL 65 AMG Black series Brake Ducts are designed to improving brake performance during dynamic road and track driving. Significantly increasing the longevity of brake pads, rotors and calipers, the Brake Ducts are the first step toward a more powerful and efficient brake setup for the SL 65 AMG Black series. RennTech front brake air ducts were designed in conjunction with front splitter to dramatically increase cooling air flow to the front brakes reducing brake fade and pad wear under the most extreme driving conditions. These bolt on components require no modification to the brake heat shield and are crafted in full carbon fiber. Whether your SL 65 AMG is equipped with iron or carbon ceramic rotors, the factory brake system is set up for everyday use and road driving. It is vital to understand that hard/spirited driving creates high temperatures around the brakes, which go far beyond everyday driving conditions. The function of the brake duct is to direct airflow to the center of the brake assembly, lowering the temperature of the brakes and lessening the possibility of brake fade. In combination with RennTech performance Brake Pads, Brake Lines, Performance Brake Upgrade, and high-temperature brake fluid (600-degrees or higher), demanding drivers and track racers can build a street and track worthy brake system for their SL 65 AMG Black series, which will save money, be safer, and make for an more inspiring driving experience.
Features
Require no modification to the brake heat shield
Increase cooling air flow to the front brakes
Drive longer between cool-down periods
Add longevity to brake pads and rotors
Reduce risk of brake fluid boiling
Improving brake performance
Reducing brake fade
Set of two (x2)
Reduce fading
Renntech Performance Package
Click HERE to order R1 Performance Package!
Click HERE to order R2 Performance Package!
Click HERE to order R3 Performance Package!
The RennTech Performance Package is the perfect entry level performance upgrade for the SL 65 AMG Black series. With the combination of the RennTechECU Upgrade and high efficiency Intercooler Pump and Airbox, RennTechis able to added more powerto the V12 engines (compared to RennTechrated stock performance). The addition of the upgraded Intercooler Pump helps the engine to perfome well and better.The R1, R2, R3 performance package increases performance at the crank, without sacrificing daily driver comfort or reliability and offer huge gains across the entire RPM range. Due to increased power and boost levels, 93 Octane or higher gasoline has to be used with R1 upgraded RennTech vehicles to avoid damage to the engine. States known for poor fuel quality have to be supplied with a lower power setup. Please call for details and Race Fuel options.
Features
Long-lasting and driver reliability
Significant gains in horsepower
Increases the performance
Significant gains torque
Increases horsepower
Increases throttle response
Increasing the engine's rev limiter
Incredible performance gains
RennTech ECU Upgrade
RennTech Proptrietary Ram Air Intakes
RennTech High Flow Dual Intercooler Pump Kit
Stainless Steel Performance Mufflers
100% Locking Differential
RennTech Transmission Upgrade
Renntech Exhaust Stainless Steel Sport Mufflers
Click HERE to order Sport Mufflers!
RennTech stainless steel (SS) sport mufflers are hand made and rigorously tested to remove any unwanted resonances in the cabin to deliver a deep sound that keeps with the character of a luxury performance vehicle. RennTech mufflers offer lighter weight than the stock exhaust and improve performance by reducing exhaust back pressure and improving exhaust gas flow. RennTech electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that RennTech proprietary air box offers incredible performance gains and rock solid daily driver reliability.
Features
Improve performance by reducing exhaust back pressure
Lighter weight than the stock exhaust
Stainless steel (SS) sport mufflers
Improving exhaust gas flow
Gains up to up to 10 HP & 15 TQ
Renntech Dual Intercooler Pump Upgrade Kit
Click HERE to order Intercooler Pump Upgrade Kit!
RennTech dual intercooler pump kit out performs any other unit on the market! RennTech upgrade replaces the OEM pump and includes an additional pump to allow maximum cooling efficiency and flow. Each individual pump flows over twice as much coolant as the problematic OEM pump and significantly more than any aftermarket unit on the market. Testing showed each Intercooler pump flows an impressive 8.7 G.P.M. @ 11.6 P.S.I each compared to the OEM pump 3.00 G.P.M. flow rate. This increase in flow dramatically removes heat from the incoming air; allowing for a denser air/fuel mixture and substantially cooler charge air temperatures over the entire operating range. RennTech pump upgrade kit mounts in the OEM location without any modifications, due to its dramatically smaller size and lighter weight and comes complete with all necessary plumbing, electrical connectors, mounting hardware and installation instructions.
Features
Allow maximum cooling efficiency
Removes heat from the incoming air
Allowing for a denser air/fuel mixture
Substantially cooler charge air temperatures
Smaller size and lighter weight
Renntech Locking Limited Slip Differential
Click HERE to order Performance LSD!
RennTech Locking Limited Slip Differential, a differential is the last point between the engine and the wheels where power is transferred. The differential functions as a system to direct engine power at the wheels while allowing them to rotate at different speeds. By upgrading the differential, you benefit in both straight line stability and vehicle handling while cornering. During a full power straight line run, our LSD (limited slip differential) will lock 100% and provide torque equally to each powered wheel, providing stable straight line runs. When exiting from a corner, our LSD's transition to the full 100% lock position is smooth and predictable. This gives the vehicle better traction and stability throughout the corner, improving overall lap times and a noticeable improvement in overall vehicle handling. The track is not the only place where the differential comes into play though. Bad weather and harsh road conditions can make the street a dangerous place. In snow, ice, wet weather and regions where the road surface can become unstable, our LSD easily adapts and adjusts tire rotation to increase vehicle stability on the road and help to dramatically improve driver safety. RennTech differential is a unique, patented, clutch- type LSD which makes this a true100% locking differential. Because of this function, there is no movement of internal parts, leading to less heat being generated while in operation and in turn, less wear of the friction disks.
Features
A noticeable improvement in overall vehicle handling
Provide torque equally to each powered wheel
Provide stable straight line runs
Gives the vehicle better traction
Stability throughout the corner
Improving overall lap times
Provide straight line stability
Increase vehicle stability on the road
Help to dramatically improve driver safety
Renntech Performance Transmission Upgrade
Click HERE to order Performance Transmission Upgrade!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech 722.9 Five speed Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability
Shift timing
Renntech Performance Toe Link Kit
Click HERE to order Performance TLK!
Adding a RennTech toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics without negatively impacting ride quality and comfort
Features
Improved vehicle handling characteristics
Maintains stability at high speed
Provide ride quality and comfort
Improve performance
Stunning good looks
Design is perfect
Simple to install
Renntech Performance Brake Package
Click HERE to order Renntech Performance Brake Package 1!
Click HERE to order Renntech Performance Rear Brake Package!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
14.2” two-piece rear rotors
4 piston rear brake calipers
Braided steel lines
16.2” two piece front rotors
Motorsport brake fluid
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
