SL55/63/65/R230 AMG: Seeking insight on dreaded ABC issue
Old Mar 8, 2020 | 02:02 PM
JamesMSama's Avatar
AMG GTS, SL55 AMG, S5 Sportback
Unhappy Seeking insight on dreaded ABC issue
Hey all, so I am grappling a bit with the dreaded ABC warnings some of us have to deal with. A few weeks ago I started getting red warning lights that would pop up as I hit a bump. The suspension felt "hollow" as if it was bottoming out. As far as the warnings, I get a ding and the left gauge says ABC, and the right says "Drive Carefully!"
I took the car to a friend's specialty shop and the hydraulic fluid needed to be refilled, which we did. The suspension noticeably stiffened back up and rides much better. However, I'm still getting the warning messages maybe 2 or 3 times during say, a 30 minute highway drive. I was hoping it would stop after the fluid bled back through the system but it has persisted.
They've suggested that I replace/rebuild the pump for the system, which I know is going to be an expensive undertaking. There is a small leak.
I figured I'd post up here and see what the voices of direct experience say. Who has dealt with this before and have you found any innovative solutions? I've searched around the forums as well.
The car is an '05 with 49k miles if that helps.
Thanks so much for any insight,
- James
Old Mar 8, 2020 | 02:33 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
ABC pump, from my experience, doesn't last much more than what you have. Buy a new ABC pump and call it a day. In addition, get an inline magnetic filter and mount on the return line right before the reservoir. It's likely you have some metal particles in your lines given the low pressure, low fluid, and leak. The metal particles can start a domino effect in your ABC system that will chew up pumps and clog the valve blocks.
Old Mar 8, 2020 | 02:36 PM
JamesMSama's Avatar
Sort of what I was afraid of hearing but I appreciate the direct and prompt insight. I'm holding my breath waiting for the price quote to come back for this...
Old Mar 8, 2020 | 07:48 PM
seven_out's Avatar
SL500, Miata
A warning when you hit a bump is the hallmark of one or two failed accumulators, though I've known the warnings to be in white lettering and not red.
They've suggested that I replace/rebuild the pump for the system...
"Suggested" suggests to me that they do not know for certain the cause of the warning messages. I believe in your case this really ought to be a straightforward diagnosis which accurately pinpoints the cause of your problem. Did they test the pump with Star Diagnosis?
Old Mar 8, 2020 | 09:56 PM
poppyboy's Avatar
2005 SL55 AMG
The pulsation dampener is often the culprit of these symptoms.
Old Mar 8, 2020 | 10:45 PM
BlownV8's Avatar
Can be accumulators or could be pump. Need to hook up a Star to determine if the pump is making enough pressure. Hope it's not the pump.
Old Mar 30, 2020 | 01:20 AM
wrightbenz's Avatar
SL55 SLK 320
I would start with the accumulators. They are not difficult to replace or very expensive and in my opinion the failed accumulators cause all of the other components to fail.
