SL55/63/65/R230 AMG: Consumer battery again
When you first get the consumer battery message connect the charger. it will likely go through the desulfation mode which can take two hours. wait two days and do it again, then a third time two days after that. The battery should then no longer give the message unless it sits unused for more than one to two weeks. My 2009 SL600 AGM lasted 8 years until I changed it. The 2005 lasted 6 years but the car was 4 years old when I bought the charger. The E63S just gave the first battery message a month ago. I ran it through the charge routine 4 times. I let it sit 2 weeks w/o using it. Started right up with no battery message. The message seems to be triggered when the battery voltage drops to 11.8V.
A 4 year old battery should be salvageable for at least a couple more years, but at this point not with a trickle charger. That is a short summary of a lot of trial and retrial of working with the AGM batteries. Good luck, these consumer batteries can be a real PITA. The good part is with two batteries the car can always be started.
You could also upgrade to something like this:
https://www.fcpeuro.com/products/aut...odyssey-49-950
Odyssey batteries are serious performers and with FCP's lifetime replacement plan, this will be the last consumer battery purchase your SL55 will need.
I have an Odyssey 48-720 consumer battery in the trunk of my 06 SL65. This car has a 40ma parasitic discharge. This is a considerable discharge for the battery to deal with. This discharge rate will kill the battery in two weeks. A battery state of charge below 70% will sulfate the plates in the battery causing permanent damage. I have a Battery MINDer hooked via pigtail to the consumer battery anytime the vehicle is parked. As you know the starting battery only turns the front starter. It does not even engage the solenoid. This battery is recharged at a rate no more that 15 amps via the module in the trunk. I have had excellent service from the Odyssey batteries in my ML, SL, and CL. In the above picture I would sure like to see a fuse on the small red (+) wire coming off the battery. As an aside Halon fire extinguishers are my favorite. The service manual has a nice writeup for preparation to measuring the parasitic draw.
A happy electrical system is a wonderful thing. I would be happy to hear your results.
Dave
