SL55/63/65/R230 AMG: ROOF LUBRICATION
Old Jul 20, 2020 | 10:45 AM
03sl55amgmjd's Avatar
2003 SL55 AMG GT , 2000 BMW 323I coupe
ROOF LUBRICATION
Guys,
If anyone has a suggestion for the best lubrication to use on the roof support brackets, I'd appreciate the input.
Sometimes I found it to be better using what others have had success with rather than adhering to M-B recommendations in the manual.
I'm in Northeast so temps get quite cold. Obviously that plays a part in the selection of the lube.
Thanks in advance everyone.
Old Jul 23, 2020 | 02:48 AM
DavidLN's Avatar
CL600, ML550, SL65
I'm going to use LPS-2 on mine. That particular lubricant has worked on the planes for years. I do like that there is an available spec sheet on this product. LPS-2 has been tested and used in varying applications similar to our hinge joints.
Dave
Old Jul 24, 2020 | 03:21 PM
poppyboy's Avatar
2005 SL55 AMG
Any helpful hints on where to lubricate? Should I just hit everywhere there’s a joint in the frame?
Old Jul 24, 2020 | 07:20 PM
DavidLN's Avatar
CL600, ML550, SL65
I would say all articulating joints. Take your time and research every hinge point. While you are there you can inspect every strut cartridge. It's like an Easter egg hunt finding them all.
Dave
Old Jul 24, 2020 | 10:47 PM
poppyboy's Avatar
2005 SL55 AMG
Thanks. Already replaced all three trunk area struts.
