SL55/63/65/R230 AMG: Radiator Hoses
Old Aug 30, 2020 | 07:43 AM
560 SEC's Avatar
2011 S550
Radiator Hoses
Anyone know how to remove the upper and lower radiator hoses? It's not a conventional clamp.
Thanks,
John P
Old Aug 30, 2020 | 12:50 PM
FxFormat's Avatar
SL 600
There is a clip inside the the connector, you'll need to pry that up and that will allow the hose to slide off, it requires tremendous force to pry the hose off if you haven't done it in awhile. use a big pry bar to push the hose off.
Old Aug 31, 2020 | 03:59 AM
560 SEC's Avatar
2011 S550
Thanks! I'm replacing the radiator, that sounds like a neck buster if your just replacing the hose.
Old Aug 31, 2020 | 04:20 PM
FxFormat's Avatar
SL 600
When doing radiator, it's a good idea to go ahead and replace the O-ring inside the radiator hose as well, there's one on the top one and one on the bottom, just use a pick to pry it out and replace it.
https://www.fcpeuro.com/products/mer...mer-0269976745
When putting the hose back on, do not use WD40, it'll dry out later and could leak, try to use the coolant to lubricate it before sliding it on. Again it'll take a lot of force to pop it back in place.
Old Aug 31, 2020 | 06:01 PM
560 SEC's Avatar
2011 S550
The O ring might have been the problem! Wish I knew that before buying the radiator. It was leaking slowly and I thought it was the neck.
The clips came off real easy. The manual forgets to tell you about the two right side hex screws that are almost impossible to get out, they face towards the fender
and no room to put a socket.
Thanks for your help.
Old Oct 10, 2020 | 05:08 AM
pmercury's Avatar
member
CL
