SL55/63/65/R230 AMG: SL55 Intake manifold gasket replacement
Old Sep 15, 2020 | 03:49 AM
_rodeo_'s Avatar
03 SL55 AMG
I found WIS instructions for other vehicles but not SL55. I suppose the process is similar but still would appreciate if anyone could share the instruction for SL55.
Old Sep 17, 2020 | 03:02 AM
_rodeo_'s Avatar
03 SL55 AMG
Bump... and going to the dealership tomorrow to pick up the gaskets. Not sure if I had to get the intake manifold bolts as well. They're usually expensive at the dealer. Are they torque to yield bolts or can I reuse the old ones? Thanks.
Old Sep 17, 2020 | 05:18 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
they are very easy to change and are a very thin piece of some type of metal? Also I reused the bolts many times. You can google torque specs but if I remember correctly 12nm?
