SL55/63/65/R230 AMG: 2003 SL 55 Electrical Clicking Sound
Old Nov 18, 2020 | 11:43 AM
iammalibuboy's Avatar
sl55
2003 SL55 - I changed out the secondary air pump relay and horn relay...now the car will barely start but runs like the computer has no control of the engine (very rough, then stalls). Tried putting the old relay back in...no change. Not sure what I did wrong, and yes they are OEM relays and are slotted correctly. With the key in the ON position there is a steady fast click, click clicking sound from the centre top of the engine at the back. It is NOT the clicking you get when trying to start with a dead battery, but sounds similar, except twice/second as long as the key is ON. Batteries are fine and this happens in the ON position, not while cranking. It sounds like a relay repeatedly clicking on and off about twice/second. Any idea what that might be and how to correct it? Pretty sure that is the source of my issue. Thanks!
