SL55/63/65/R230 AMG: Consumer Battery Drain Overnight
Old Feb 8, 2021 | 10:00 AM
Sl500Kleemann's Avatar
SL 500 Kleemann S/C
Hello , I have constant drain of the consumer battery overnight, we tried to diagnose it but when the car is turned off it shows no drain. We assume something is turning on and off at random times and draining it. We started disconnecting different modules ( first on the list was PSE pump) but it didn't help.
Can anyone with some experience with this problem point me in some direction at what else to look at?
P.S : I had this car for 5 years now and and this problem is recent ( maybe 1-2 months old)
Old Feb 8, 2021 | 05:10 PM
poppyboy's Avatar
2005 SL55 AMG
How old is the battery? Do you normally keep it on a maintainer? These batteries have a constant draw from various modules, even when off-line.
Old Feb 9, 2021 | 12:31 AM
Zoso7's Avatar
06' SL65, 96' S500 & 09' S550
I agree with @Poppyboy. The R230 is not the car you take to the airport to leave in the upper deck for a few weeks. I keep a battery maintainer on the consumer (trunk) battery full time. Sometimes there are two maintainers on my SL65 when I'm also plugged in to the starter (under hood) battery. Normally these two battery circuits degrade in isolation. The consumer battery is the one to keep in good health as it runs most everything except the starter motor itself. This SL likes to taste electricity, that's just the way it is and you can see that when the Comand screen fires up with the logo when you do just about anything with the door or boot.
Old Feb 9, 2021 | 07:40 AM
SL 500 Kleemann S/C
Battery is brand new I charged it to full again after it drained and overnight it was empty again, before this problem occurred I never had any battery problems maybe it would be drained if i didn't drive it more than 2 weeks.
Old Feb 9, 2021 | 08:09 AM
poppyboy's Avatar
2005 SL55 AMG
You may have a leak in a PSE line, causing the pump to constantly kick in, but I think you said you tried disconnecting the pump for a period of time already.
Old Feb 11, 2021 | 02:30 AM
SL 500 Kleemann S/C
Yes, I did few more test when I unplugged the PSE pump it drained again but just to 70% so there is some sort of leak in the PSE pump for sure, but there is a leak somewhere else too.
