SL55/63/65/R230 AMG: Suspension rubbing issue.
fast forward: I just had to replace my front torque struts, lower ball joints and tie rods (outer, then on inspection inner). Did all that, lots of fun, watched the FCP Euro videos and I felt I followed all the right steps.
Now, all finished, took her for a test ride, and noticed a metal-on-metal noise at full lock. On inspection it’s the inner edge of the rim rubbing on the torque strut. Not good.
Thought it was too much toe in, so took it for alignment. Had that done, and still got the issue (less, but still on full lock.
Obviously undriveable, but I’m wondering why it’s happening: did I do something wrong? Did the previous shop align me slightly toe OUT, to keep the wheels clear of the frame? My immediate solution would be a 5mm wheel spacer to push the inside of the wheel off the strut on full lock, but that could be treating the symptom, not the issue. I THINK I’ve got the clearance on the arch, so viable but crude solution.
any experience welcome!!
wheels BC Forged, 9” wide, but standard width 245 tyres.
torque strut bolts are uneven - one is a simple round axle bolt, the other has the groves to set camber. The shop has it as 2.1 and 2.3 camber - the one with the grove being the 2.1. Both sides rub, so can’t see the relevance.
