SL55/63/65/R230 AMG: Parts availability for 2003 SL55 AMG?
The diagnostic work for my car has been done. It turned out that the oil leaks were a combination of hydraulic fluid leaking from both sides of the steering rack and also the rear main seal of the engine has failed. To fix that, the transmission has to come out. Some other weeping hydraulic joints, a regular oil service, replacement belts and air filters, replacement steering ball joints, four wheel alignment and on and on.
Total cost (including taxes)? £5850 or $7340. Perhaps I need to revise my 25% maintenance rule of thumb…
As for 25% rule, maybe if you average out over several years, it may still be 25%.....? Maybe you won't have any issue next year.
What and when was the last repair and how much you paid for it, if I may ask....
Thing is, there is so much in this car that can and does go wrong that each owner’s experience is different and it’s always interesting to compare notes when I meet one. “How has it been for you?” I persevere because it’s a striking car to look at, better I think than the later facelift models which we would say here were a bit “bling”. It also has a decent turn of speed at least by the standards of the day but is perhaps seen as an older man’s car here in the UK, I was 47 when I bought mine, I’m 67 in May!
I think SL is also considered to be an older man's car here in the States, too. But with AMG badge, it lowers the age. :-|)
996, Cayman, SL55AMG, or keep my C5Z6. I will continue enjoying this process!
Here’s my 10 point guide to R230/SL55 AMG ownership:
1. Cheap to buy, but for a reason.
2. If you are buying, get the car checked over and look for a solid maintenance history, preferably main dealer.
3. Routine maintenance is relatively inexpensive.
4. Other maintenance done properly tends to be expensive in terms of parts and labour.
5. Such maintenance is beyond the abilities of most independents.
6. Limited scope for doing work on it yourself. If you do, you need the tools, time and space.
7. Most important is to keep the trunk dry; keep the C pillar drain holes clear and check the seal across the back of the roof. Run a hose across the back of the car to check for water ingress.
8. Keep the car on a trickle charger (rear battery only) when not in use for more than a few days.
9. If you sense a problem, it’s unlikely to go away and is likely to be expensive to fix.
10. The car is great to drive but less suited now to being a daily driver. It’s for the weekends and trips away.
