SL55/63/65/R230 AMG: What is this gold thing on side of ABC pump?
New to this forum, I'm an automotive engineer (so I'm probably over-complicating this in trying to understand it instead of just swapping the part and moving on...lol).
Questions I can't find answers to:
- what is this gold thing mounted to the side of my ABC/power steering tandem pump? (it is leaking) Is it a power steering pulsation dampener? (not ABC pulsation dampener)
- I believe they are the same fluid, but do the fluids from both the power steering and ABC system stay separate or interchange/intermix? because I don't understand how a powersteering component issue is causing issues with my ABC system
symptoms:
ABC fluid low in reservoir
dash showing drive careful and red ABC warnings when fluid was low. (no warnings once fluid was topped back up)
all ABC works fine when fluid is topped off
no issues with power steering performance or fluid levels
green hydraulic leak coming from gold thing on side of the tandem ABC/Power Steering Pump
leak on my vehicle
The red arrow is pointing to the area where the leak is coming from
pump, and tandem reservoir deal. If you have low fluid, you have a leak ( which you have confirmed) but may have other issues.
My suggestion is to do a complete preventative maintenance on this system now before you regret it. Fluid, accumulators, filter, and hose visual check. the fluid is probably filthy.
It will be a bear to remove but I think it should be possible without removing the pump.
Re-welded and ready to re-install
I seem to recall that removing and replacing the damper and bracket was NOT particularly difficult.
Hope that helps,
Chris
