SL55/63/65/R230 AMG: Problem: 6'9" and want an SL55, what can I do?
I am 6'9" as well and have a tight fit but no real problems. I am sure that you have tried all the settings but I fit fairly well. I guess at that height it may be how you are proportioned. Any taller and my head would be hitting. My legs are tight but I still have enough room between the wheel and my legs to move the wheel freely.
You can also look at aftermarket racing seats that will give you a bit more travel.
Schiznick
Maybe you can have a good upholstery/custom seat shop modify the mounting rails of the seat so that you can drop the seat height an inch or 2 as well as the length of the runners. I'm not nearly as tall as you at 5'10" but I just checked my driver's seat range of motion. When I move the seat all the way back it can't get any closer than ~1" away from the storage bin. If you tilt the seat back more and more the bottom of the seat moves forward. I'm sure that a shop that does upholstery and custom seats can modify the way the seat travels, increase the running length (remount OEM rails or replace OEM with longer rails?) and lower the seat mounting height (seems like a lot of room there to work with). That could mean much more comfort of an additional 2"+ in height and 1"+ in length for you with little additional cost. I recall that there are shops that do this for NBA/Football players and an article I read (DUB?) showed that it wasn't very difficult as long as there is some room to play with. It isn't a unique modification and there is interest.
That is what I am thinking. I had to do this with my H2, but that car seemed to have much more room to work with. Suprisingly, I have plenty of head room, it is the legroom that I could use more of! I am thinking that a good shop might be able to squeeze out another 2" of leg room. That would be perfect.
