SL55/63/65/R230 AMG: SL55 Interesting Coolant Pump Wiring
Found out that the Bosch pump had already been fitted but the wiring had been changed! The original wire had been cut at the plug and a new wire has been spliced into a loom, I have no idea why. I traced the wires back up to the loom and found this under the wiring compartment in the engine bay...any idea why anyone would have done this? I'm not sure what wires they've spliced into.
What's the best way to test if the pump is receiving power? On my CLS55 it would run for about a minute or so when ignition was switched on but this doesn't seem to be happening with the SL? Is it meant to? I want to make sure that the wiring is fine before fitting the new pump. Any ideas.....?
IC Pump Wiring
