SL55/63/65/R230 AMG: R230 check engine light. Smog Pump?
I had the smog pump replaced about a year ago.
If I disconnect the consumer battery to reset, the light will stay of for a few days before it comes back on.
I have even driven the car on a 500-mile trip with no check engine light. Drive around the city a few days & it comes back on. I unplug the trunk battery again to reset.
CEL light stays off for some days then comes back on. I'm puzzled.
My friend/mechanic said maybe it is carboned up? This is my mother's car & has been babied.
I figured I'd run some BG 44K fuel system cleaner though it. I don't know why, just trying anything.
Hoping someone may have some advice for me. My friend is a great mechanic & has his own shop for German cars.
I'm not scared to take it to the MB dealership. I just need to do some bend over stretches & buy some lube.
Any advice or questions would be great. Thanks in advance.
I need to enlist the help of a friend.
The smog pump was replaced. I did not know it had a secondary air pump. Genuine MB parts have been used though out.
My mother basically did nothing to the car for 20 years but buy gas, change oil, some tires & drive it less than 2500 miles per year.
Here's my list of work I have had done at my buddy's shop.
Valve cover gaskets.
Engine mounts
Transmission mount
Electronic/hydraulic struts
ABC Accumulators
ABC hydraulic hose (1 of 4)
Flush ABC system
New Gas Tank, baffles broke loose.
Batteries
Battery Tender charger/maintainer w/ extensions cords
Emissions Air pump
Engine Oil
Engine Air-filters
New Tires
4-wheel tire Alignment
O2 sensor
Hatchback struts
Center console strut.
I am thankful for any help or advice.
