SL55/63/65/R230 AMG: Supercharger oil maintenance
Old May 16, 2024 | 06:46 AM
renncoder's Avatar
2013 Porsche 911 Carrera 4S, 2004 SL55, 2012 Lexus IS250, 2021 Toyota Highlander
Question Supercharger oil maintenance
Hi all...
When is the appropriate time to change the supercharger oil? Mercedes doesn't define what a lifetime is for the supercharger. Should I be listening for something or is it at some interval?
Old May 16, 2024 | 03:28 PM
HLG600's Avatar
2009 SL63 AMG
If original, I would change it regardless of mileage.
I've read ~50K miles as an interval, but after seeing what the fluid looked like on my S55 with ~55K miles on it at the time, I decided on a 25K mile interval moving forward.
Old May 19, 2024 | 12:19 AM
tonylinc's Avatar
SL55AMG, GL450, SLK, S550, Maserati Coupe
Old May 24, 2024 | 12:08 AM
Iceclimber7's Avatar
SL55
I just did the change tonight with the help of this video.
I extracted 140 ml which seemed like a success. Took some fiddling with tools and finally a 1/4 drive ball hex socket with a wobbly extension was the perfect way to get that stupid plug reinstalled. I dropped it twice and found it ...and I ordered replacements for when I drop it next time. Also my plug looks like someone struggled with it...all the more reason to get spares. Now that I figured it out I will probably change it again shortly considering the stank of the oil that came out. Also I read a lot of people filling the sump until it comes out the fill. By the looks of the diagram that seems like twice the spec of 150ml. To each their own, but I followed the spec.
Old May 24, 2024 | 03:43 PM
tonylinc's Avatar
Good job, overfilling is not recommended. It is best to use the right exact stuff (pictured) and the exact correct amount. I bought the oil and a syringe kit, but haven't done the oil change yet myself, for fear of dropping and losing that plug. Where did you get your spares?
Old May 24, 2024 | 06:56 PM
SL55
https://belmetric.com
I magnetized everything first which helped me find it, but I was lucky. Thing is designed to get lost.
Old May 24, 2024 | 07:22 PM
SL55
b4
not b4
Off topic, but before and after grill
