SL55/63/65/R230 AMG: SL63 DIAG! NO CODES! BOGGING INTERMITTENTLY!
Old Jun 12, 2024 | 08:23 AM
boostedxbrandon's Avatar
2018 SL63
Hello I have a 2018 SL63 AMG (M157) that has a horrible intermittent issue where it bogs down really bad when given power from a stop like it has no power and wants to die and if you keep the gas pressed it will regain its composure and the incident might not happen for up to 30 stops, interesting thing is that the car has no codes from the incident as if it was all within parameters, it could be also described as shuttering but it's very intermittent. Anyone heard or had this issue? Or would know where to look next I've already been told by a Benz tech to change the MAP sensors and 8 hours later had the manifold out but it changed nothing.
Old Jun 14, 2024 | 02:17 AM
BenzNinja's Avatar
Former Vendor
You can keep guessing but without a proper diagnostics you'll go nowhere
