SL55/63/65/R230 AMG: secondary air injection help
i mean if it's not the fuse what else could it be?
We usually code out all
no need to remove or disconnect either
I have replaced the sai pump, the switch over valve and the relay. The CEL still comes on intermittently, every now and then. Just came back from a 70 mile run. Urban, stop and go, freeway. NO CEL..
Am looking at the two EGR valves next to the blower in the front of the engine. No vac leaks. Idle smooth at 550.
Any more ideas. Car has 108K miles.
