SL55/63/65/R230 AMG: r230 door window issues
Old Apr 16, 2025 | 10:40 AM
jeff2218's Avatar
when i shut door window won't close last couple mm. also won't go up with window control. this started after i removed inner door panel to replace mirror assembly,after putting it all back together new mirror worked fine, but window just won't go all the way up. don't see any loose connections all the plugs are tight, just don't know where to look now.
