SL55/63/65/R230 AMG: Distronic grill mistake
Old May 8, 2025 | 10:17 AM
Iceclimber7's Avatar
SL55
I replaced my SL55 grill with one from mad hornets and in my infinite wisdom (I didn't even know what distronic was) got a grill that doesn't work with my cruise.
Anyone have a line on just the emblem that will work with distronic ? I have seen talk that the emblem can be modified but can't find the deets.
Prefer not to shell out for another grill.
Old May 11, 2025 | 03:13 PM
SL55
In the long tradition of replying to my own threads, there is no easy way to modify the grill to add the correct baseplate and opaque emblem. So, new grill or no cruise. Yay me.
Old May 13, 2025 | 04:37 PM
mrvedit's Avatar
2004 SL600
Interesting info. I have replaced my grill with a cheap one off ebay, but have never tested the Distronic either before or after the grill replacement. I will try it this week and report back.
Old May 17, 2025 | 08:44 PM
SL55
I think I know what your report will be.
Old May 19, 2025 | 06:56 PM
mrvedit's Avatar
2004 SL600
I tested my cars Distronic cruise control today and it seemed to work correctly. As mentioned above, this is with a cheap $190 grill replacement from ebay.
I say "seemed to work" because this was only the 2nd time in my life I have used a distance based cruise control on any vehicle; I'm not much of a cruise control user.
Today, when I enabled the cruise control while behind a car, a white icon appeared at the top of the speedometer. The dial by the shifter allowed me to control the distance to the car in front; turning it forward brought me closer. When the front car switched lanes, I lost the icon.
Old May 19, 2025 | 07:52 PM
SL55
Can you post a link to the one you bought please. If you look at the center, the Mercedes star round part should be like a grill so the sensor can see through. Regardless sounds like you were luckier than I was.
Old May 20, 2025 | 07:39 AM
meadows222's Avatar
'05 SL55 AMG, '00 SL500, ‘99 SL600, '83 380SL, '15 S550 Coupe
Originally Posted by Iceclimber7
…the Mercedes star round part should be like a grill so the sensor can see through.
Pretty sure that’s wrong.
Old May 20, 2025 | 09:26 PM
VRV000's Avatar
SL55
The MB star in a Distronic grill is smooth plastic. On cars without Distronic, the star is 3-dimensional, with the mesh grill showing in the background.
Old May 21, 2025 | 02:41 PM
mrvedit's Avatar
2004 SL600
The MB start on my grill is very slightly 3D with nothing behind it.
The link to the grille I bought no longer works on Ebay; I might be able to determine the seller later this week.
The closest I could find is this one: https://www.ebay.com/itm/146585032286
Although mine is chrome colored plastic.
You might try removing the MB emblem to see that the Distronic then works.
Old May 21, 2025 | 11:59 PM
SL55
Thanks all, and I was wrong about the correct star yes it's flat plastic. I dug the old grill out of storage and reinstalled and viola distronic works perfectly. Also after an evening cruise around the lake with the top down, can I just say the SL55 at twenty plus years old is simply an amazing car.
