SL55/63/65/R230 AMG: Power steering rack leaking
is there an additive you could put in to stop the leaks?
A good way to ensure power steering leaks, is to hold pressure against the stops, so that the pump bogs down, and starts groaning.
Know your stop to stop rotation, and only ever APPROACH the stops.
Then, you will have done all you can, to prolong the life of the power steering system without leaks.
Note that this is power steering fluid, not ABC fluid. As mentioned, your car has a combination Power-Steering and ABC pump - two pumps on same shaft but using different fluids.
Personally I would not use a "Stop Leak" as that can gum up your pump, rack and cooling lines.
