SL55/63/65/R230 AMG: ECU and pulley upgrade?
I contacted all three yesterday and while I have not gotten a reply from EVO or Kleemann, Renntech responded saying that "like any modification it will void the original warranty", but added, "we have not had any problems yet". What worries me in this case is that something goes wrong unrelated to the ECU upgrade and MBUSA still refuses to honor the warranty.
We all spent upwards of $140K on our sleds so I'd think that most of us are cautious 'changing anything'. Any input here would be appreciated...
~ Ian
From what I've seen, upgrading the ECU only will make the car drive more smoother and feel faster by increasing the throttle response, but usually does not lead to high hp gains.
He is located in MD, and only charges $349 to flash your ECU which also removes your limiter in additon to the better throttle response and extra HP and torque.
The car drives great, has noticibly more punch and the limiter is gone!!! Well worth $349. Those other guys who charge thousands for the same thing are crooks and should be ashamed of themselves.....but I guess if they have customers willing to fork out the dough......
I agree with you 100%. Why pay $2K-$3K more for just a ECU if that is all you are looking for. Since I live in MD, my down time would be the 20 minute drive to see Oliver and the 30 minutes for him to flash my ECU. Seems like a no brainer to me for the cost.
Personally, the cost is my third concern behind WARRANTY and QUALITY. Warranty being paramount by a wide margin.
~ Ian
I was told that the SL55 chip puts out another 30 hp and 30 tq + no limiter!
However, I will only be making upgrades to the SLK55 first.
You will love the the work from Oliver. How much increase is he claiming for the SLK?
I'm just saying this, because my wholesaler for BMW performance parts, AA tuning, just does this. It save a lot of time & money. When you order a supercharger kit from them, you don't have to send them your DME, they will give you the software transfer system so you can do it yourself. Quite impressive.
Speedtuning dyno charts are very similiar to all other tuners for just having the ECU mod. For $349 I would take a ECU flash anytime and have the same results. You have to be nuts to pay $2K-$3K more if you are looking for just a minor ECU tuning.
I would assume if something went wrong with the car that Mercedes could test the flashed ECU, discover it was altered, and void the warranty. Now if you buy a chipset, you could swap back the old ECU and avoid this possibility altogether no?
After paying 130-140K for our AMG to start with, I would assume that saving $2-3K and voiding the warranty wouldn't be saving much in the long run... Just my 2 cents.
~ Ian
~ Ian
The Brabus K8 kit includes additional coolers as well. When you change the pullies and ECU, the pulley belt life is largely governed by heat stress. Therefore Brabus add additional coolers and new pulleys on every single component to make sure all relative gearing is correct. Extreme heat causes the pulley material to deteriorate, so they use a new longer eight-ribbed belt, and as the belt transfers its heat to the pulleys, which act as a heat sink, they use special ventilated pulleys with greater surface radiating area to keep the whole belt and pulley system as cool as possible.
The factory IHI supercharger is running at 0.8 bar of boost, and at peak revs consumes 91bhp. The Brabus conversion runs 1.1 bar boost and the system consumes 106bhp, but gives back 50hp and 80NM more.
Brabus also use a special radiator with 50% bigger capcaity. As the AMG intercooler is a water/air type under the supercharger, it is vital to cool the liquid as fast as possible. They use an additional intercooler and a second electric pump to increase the flow around the whole system. They also have an additional oil cooler in the front, the resultant modifications let Brabus use the 1.1 bar boost with no problems. The power increase is well within the parameters of the standard fuel injectors, so they are untouched, but the ECU is modified to look after the different fuelling, ignition and boost requirements....
Not as simple as a pulley and chip mod is it? Agreed, its not worth it, but they sure do the R&D for their work and with a three year warranty, it looks tempting...for the newbie buyer.
If you guys want to go faster....you would be far better off 'investing' the $2-3K in a high performance driver's school. You will find the results far more rewarding that the power gains and then you will find exploiting the power that you have available (which is HUGE) unbelievably rewarding.
I have outrun some seriously fast cars at the track and on mountain roads with a pretty stock SL55. I'm not trying to say that I'm something special....but there is nothing to replace great education and lots of practice!
- TheInsider
I can't wait until April to put the chip in; I'll be sure to let you know how the car runs.
And BenzoAMGpower, I would really like to see your car in person. The CF hood and all other mods you've done look awesome! Keep up the great work!
